Old 03-12-2018, 10:16 PM   #1
bmchevy1979
bmchevy1979's Avatar
SM465 Issues (PLEASE HELP!!)
Hello Everyone,
I alao asked in the engine & drivetrain section but figured I'd get better responses here so I have a problem I was driving my k5 to work this morning and I came up on some slow moving traffic so when I had an opportunity to pass I downshifted to 3rd and got around the vehicle in a timely manner but when I went to shift back into 4th the shifter was stuck in gear. I was almost to work so I just cruised in 3rd. I've already pulled the shifter and tried lining up the shifter gates with a bar but it is stuck. I also pulled one of the PTO covers off and everything seems to be in place. I also tried removing the cover but I can't get the cover off without putting the tower part way into reverse which won't happen if it's in 3rd At least that I can think of. So to my question, is there any way to remove the shift tower with it jammed in gear? I honestly believe it's something with the shift tower detents.
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 03-12-2018, 10:18 PM   #2
andyh1956
Re: SM465 Issues (PLEASE HELP!!)
Sounds like you're gonna have to get rough with it, maybe rough enough to break something. Good luck!
andyh1956 is offline   Reply With Quote
Old 03-12-2018, 10:36 PM   #3
bmchevy1979
I have that feeling as Well.
<Brandon>
Old 03-13-2018, 05:23 PM   #4
bmchevy1979
Ok so an update I was able to get the shift tower off. And it isn't stuck like I had originally thought the shift collar for 3rd & 4th gear is stuck on 3rd it's free floating but won't slide back to neutral
<Brandon>
Old 03-13-2018, 10:37 PM   #5
andyh1956
OH OK then the sliding clutch for 3-4 syncro is the problem.
Most more likely the keys have become dislodged under the sliding collar. There are three of them held up against the bottom of the collar w' two springs. The blocking rings fit against the keys w/ notches cut into them. Look to see if you can see any of them outta the notches.
Old 03-16-2018, 08:12 AM   #6
bmchevy1979
Ok thank you I am getting ready to buy a rebuild kit I'll add these to my list and just start fresh this time when I put it back in I pulled it out the other day after work
<Brandon>
