03-12-2018, 10:46 PM | #1 |
Tightening ignition switch retainer nut
What do you use to tighten the three slot ignition switch retaining nut?
1968 SWB Step Side, Big Block, 4L80E , Running! |
03-12-2018, 11:02 PM | #2 |
The Older Generation
Re: Tightening ignition switch retainer nut
These are available from most parts vendors.... I made my own from a piece of thin wall tubing. LockDoc
03-12-2018, 11:30 PM | #3 |
Who Changed This?
Leon's nicer to the bezel nut that I have been. Use his solution and leave the screwdriver and rubber hammer that I used in the tool box. There is a spanner made for this application, but most people don't buy it if they go to a shop for their repairs.
03-12-2018, 11:35 PM | #4 |
The very first thing you'll do AFTER you hit the screwdriver with a hammer and drag the tip if it all across your dash is rush out and buy the $8 wrench for ignition bezels
Many of them have a little bar welded across the top so you can tighten them sufficiently by hand. EDIT: one note - be careful the first time you use one with a bar on it - it may hit your dash bezel and scrape the chrome plastic - just be aware, easy to not see it coming... Last edited by jocko; 03-13-2018 at 10:30 AM. |
03-13-2018, 08:33 AM | #5 |
Do local parts stores carry these or do they need to be bought online?
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
03-13-2018, 09:03 AM | #6 |
The Truck and Car Shop in Orange California has them for $9.00 plus shipping.
03-13-2018, 12:11 PM | #7 | |
LockDoc
05-14-2022, 07:20 PM | #8 | |
While I'm at it, what about the tool for the other switch bezels? Thanks for any input. |
05-14-2022, 09:14 PM | #9 | |
Evidently you are looking for a tool for the '67 bezel. You will probably have to make one. For the light and wiper eschuctions I use a pair of needle nose pliers. They really shouldn't be that tight. LockDoc
05-14-2022, 09:23 PM | #10 | |
I bet cj847 is hunting for the 67 socket tool. The Bezel is 1.025 inch inside diameter. The slots is 1.125 inch maximum inside diameter in 3 places. They are about 0.100 inch wide. The depth is just over 3/4 inch.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 05-14-2022 at 09:31 PM. |
05-14-2022, 09:41 PM | #11 |
This just popped up in the Amason search.
The review says it won't work on Large Bezel??? Link:https://www.amazon.com/Ignition-Swit...8WTTQV5G&psc=1
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-15-2022, 06:07 AM | #12 |
https://gmcpauls.com/dash_parts.htm
Part # 1507761-2 1967-68 Early Ignition switch bezel removal tool required to remove ignition switch bezel from ignition switch without damaging or scarring process. Don't scratch your up bezel, use the right tool for the job! Made In The USA This is the aluminum CNC version with cross bar for the smaller 1967 and early 1968 ignition bezel. Ignition Bezel Tool Headlight, Wiper, Choke & Throttle Bezel Tool Paul Jr @ GMCPauls Last edited by GMCPaul; 05-15-2022 at 12:26 PM. |
05-15-2022, 09:23 AM | #13 |
Thanks for the help. Yes its a 67. I see GMC Pauls has a tool.
05-15-2022, 09:29 AM | #14 |
Way to come in there Paul.
I should have thought to look on your site
