Old 03-12-2018, 10:52 PM   #1
chrismoore701
chrismoore701's Avatar
Stripped out heater box
I was replacing my blower motor this weekend and the holes in the box are stripped out. I squirted in some fiber glass resin and drilled out and it did not take. Any thoughts out there? Should i drill out bigger and jam some fibers in the hole? Seemed like the resin did not adhere to the box. I have a 79 c10. Fiberglass box.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-12-2018, 11:11 PM   #2
Ziegelsteinfaust
Re: Stripped out heater box
What about those clip on nuts or using butterfly bolts
Ziegelsteinfaust is offline   Reply With Quote
Old 03-13-2018, 03:32 AM   #3
Jaysonb
Jaysonb's Avatar
I would clean out the resin you put on there, and chop up some fiberglass mat and mix it with some epoxy, then fill and re-drill the holes after it sets up good.
Jaysonb is offline   Reply With Quote
Old 03-13-2018, 07:24 AM   #4
Bandit130
Bandit130's Avatar
Would any of these work for you?
https://www.google.com/search?q=u+nu...EIdzAG#imgrc=_
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 03-13-2018, 10:31 AM   #5
chrismoore701
Those clips could work if i modified the box. The box is flat. But each screw hole has a thicker portion added to give the screw more to bite. I would have to cut these off. An option of my glass fiber option does not work
Chris
Old 03-13-2018, 03:36 PM   #6
blindbug
How about a rivet nut insert?
https://www.amazon.com/dp/B072QWZPWK
Or possibly a threaded nut insert? You can tighten the insert down, clamping it onto the heater box. Add in some loctite or epoxy and it should never come out while backing out a screw.
https://www.amazon.com/dp/B00YJDZ2JS
blindbug is offline   Reply With Quote
Old 03-13-2018, 07:01 PM   #7
v30crewcab
v30crewcab's Avatar
rotate it slightly and make new holes.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-13-2018, 08:09 PM   #8
chrismoore701
Good ideas. Some things to think about. Thanks guys
Chris
