Old 03-13-2018, 01:09 PM   #1
lowbucktrucks
L31 Vortec 350
There seems to be some confusion or contrversy as to whether rams horns will work on L31 vortec. Has anyone used vortec log manifolds on our trucks?? Just wondering if they will fit our frames?? Thanks
lowbucktrucks is offline   Reply With Quote
Old 03-13-2018, 01:21 PM   #2
harpo231
harpo231's Avatar
Re: L31 Vortec 350
On the L31 Vortec heads, the exhaust ports are not centered on the bolt holes. This results in a mismatch of the exhaust ports of the heads with any manifold or header other than the L31 manifolds. Really not sure why GM did this.
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-13-2018, 02:23 PM   #3
B. W.
B. W.'s Avatar
Re: L31 Vortec 350
pic 1: L31, 2.5" corvette rams horns
pic 2: stock manifold with L31 exhaust gasket
B. W. is offline   Reply With Quote
Old 03-13-2018, 02:27 PM   #4
truckster
truckster's Avatar
Re: L31 Vortec 350
Yep. thousands of swaps have been done using the L31 and the rams horns or headers. I haven't heard of any problems (except the typical leaking header problems).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-13-2018, 02:55 PM   #5
AK49Watson
Re: L31 Vortec 350
I run headers. They barely leak. A couple pinholes, that's it. Can't even hear or feel it.
1970 GMC C2500, Vortec 406SBC, TH350
AK49Watson is offline   Reply With Quote
Old 03-13-2018, 09:23 PM   #6
lowbucktrucks
Re: L31 Vortec 350
Will it work with factory rams horns or does it have to be corvette 2.5 inch??
Old 03-13-2018, 10:32 PM   #7
Jrainman
Jrainman's Avatar
Re: L31 Vortec 350
Harpo is correct the exhaust studs are set lower and not centered as in the older gen1 sbc head , just hang a set of sbc gaskets on and you will see this so ,there will be a small amount of interfearance at the top of the ports , will the rams horns fit yes they will and any gen 1 sbc exhaust manifold or header will fit, some guys say you want to use round hole gaskets and headers in stead of the oval/d port gasket and headers , I did some grinding (porting) and a little gasket moding to my headers so there was no interfearance issues on my vortec heads, also the rams horn might be close to your spark plug boots and cause issues . If you are staying with manifolds if I remember rite the best ones you can use for the vortec heads are out of a vortec year 3500 series truck I think ,I could be wrong but I know that there is a certain stock manifolds that is is highly prized for there flow on vortecs by the circle track racers being thety have to conform to stock manifolds those would be the people you want to ask.
Jrainman is offline   Reply With Quote
Old 03-14-2018, 12:58 PM   #8
B. W.
B. W.'s Avatar
Re: L31 Vortec 350
If it's 4wd you can run either stock or the larger ones. The corvette's only come int straight dumps I think. If it's 2wd you're better off with the stock angled exit for clearance, though some guys here have made the straight dumps work.
I have a stock L31 manifold so I compared it with the rams horn manifold using an L31 specific gasket (MS16093):
Old 03-14-2018, 02:28 PM   #9
truckster
truckster's Avatar
Re: L31 Vortec 350
Interesting. It looks like the rams horn is a better match to the gasket than the stock manifold.
