Old 03-13-2018, 02:31 PM   #1
Android04
Android04's Avatar
Air Ride - which track bar/panhard bar
Good afternoon everyone. So I am in the process of installing all of my air ride and need to order my track bar. I was hoping to find one at the local swap meet this past weekend but didn't have any luck.
For everyone on air I've read that the longer the better so I was looking at the Classic Performance Trac Bars CP32021 or Classic Performance Trac Bars 6572DTBK. I was set on buying one of these but read some reviews that it doesn't work with air ride.
Any suggestions here would be great because I'm going to order it today.
EDIT: Truck is a 1965 SWB
Android04 is offline   Reply With Quote
Old 03-13-2018, 03:23 PM   #2
jweb
jweb's Avatar
Re: Air Ride - which track bar/panhard bar
I haven't gotten to it yet, but I plan to use the Dead End Garage panhard bar.
https://www.azproperformance.com/Dea...63-72-C10.html
It should work well with air ride, I believe Travis from AZ Pro Performance is using the same setup on his Suburban. You can give them a call to verify.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 03-13-2018, 04:14 PM   #3
slowcpe
slowcpe's Avatar
Porterbuilt also has a standalone trac-bar.
The DeadEnd Garage one looks good as well. The one thing I really like about DeadEnd's setup is it looks like you can get their c-notch with the upper trac-bar mount and upper bag mounts built-in.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 03-13-2018, 05:11 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE Super Track Bar is a good choice.
www.earlyclassic.com
Keith
Convert to disc brakes.
Old 03-13-2018, 06:41 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I'm using POL - https://www.performanceonline.com/19...-Bar-Trac-Bar/
Old 03-13-2018, 06:53 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
This is what I used, but I fabricated and welded a bracket to the back of my passenger side trailing arm. This was long before CPP, POL, and others offered that type of track bar mount option.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-13-2018, 07:25 PM   #7
LVPhotos
LVPhotos's Avatar
Porterbuilt 62 frame
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-14-2018, 08:21 AM   #8
Android04
Android04's Avatar
Thanks everyone it looks like what most of everyone is using aside from the Porterbuilt looks much like the CPP piece. So I'm going to go with the CPP one since everything else is CPP at this point.
Thanks again!
Old 03-14-2018, 11:48 AM   #9
lolife99
lolife99's Avatar
Thanks again!
Make sure you buy from a company like Summit Racing for your CPP parts.
There are lots of horror stories from buying directly from CPP.
Keith
Old 03-14-2018, 11:56 AM   #10
LVPhotos
LVPhotos's Avatar
Yep! I had mine thru Tuckers here in LV and none were the right length as advertise... someone couldn't read a tape. Finley the just ordered a long bar and cut and welded it.
When an adjustable is 32 " and is sent 28"???
Old 03-14-2018, 01:12 PM   #11
Android04
Android04's Avatar
Thanks again for the heads up. I ordered it through Summit Racing along with a CPP front sway bar.
Old 03-14-2018, 01:58 PM   #12
Bentbolt
how much side to side change when bags are up vs down?
Bentbolt is offline   Reply With Quote
Old 03-14-2018, 05:08 PM   #13
LVPhotos
LVPhotos's Avatar
I set ride at 3" on shocks so effectively 6" stroke. The movement is less than stock. The stock 62 bar is just in front of the crossmember and all the way out by trailing arm, enough to contact frame I know the 63-72 were short and my rear is a 72 with built in mount. This would move more in an arc.
I would say at a 4ft bar it moves 1/16 to 1/8 inches. Need sway bar to help side load and roll center.
You want the bar as long as possible and parallel to the ground.
More pic on build page
Old 03-26-2018, 01:31 PM   #14
Android04
Android04's Avatar
What shocks are you guys running with air ride in the front? I did a relocation kit in the rear. I have a 3 on the tree so the relocation kits aren’t friendly for the front. So I’m just going to run a shorter shock. I read the Monroe 33033 will work but the compressed length is no shorter then my currents.
Any suggestions?
Old 03-26-2018, 05:51 PM   #15
LVPhotos
LVPhotos's Avatar
KYB, available at O' Rielys,
Old 03-27-2018, 08:42 AM   #16
Android04
Android04's Avatar
So you are using a relocation kit with a KYB Shock? Do you have the KYB part number by chance?
Old 03-27-2018, 08:56 PM   #17
LVPhotos
LVPhotos's Avatar
Not sure of # but you need to measure and use the one that works. Ride, down, up height. Stem or eye, its your set up. I usually roll with 3" of shock at ride height. 6" total.
