Dual tanks without switching valve?
This is a complete rewire situation, so none of the factory stuff applies.
It appears I can put a '87 tank, '87 pickup, ep381 pump, and corvette filter/regulator on each side of the truck. Install a check valve after each regulator, tee them together, and run one line to the fuel rail. The switch on the dash would be a double pole, double throw type. One pole would flip the fuel gauge between tanks; the other pole would send power to one of the pumps. Has anyone done this? It appears to me it would be a much cleaner install than using a selector valve. Last edited by kipps; 03-14-2018 at 10:19 AM. |
Re: Dual tanks without switching valve?
i am interested in this fete. a buddy of mine is trying to accomplish the same thing.
![]() Join Date: Sep 2005
Thats baslicy how ford did it on the older f-150s
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
| Bookmarks |
