Old 03-14-2018, 12:12 PM   #1
msg
Drum brakes replacement parts?
Ive never done any brake work other than dismantle the ones I have. I had taken this all apart a few years back and saved all the parts thinking to maybe sandblast them but I would think a replacement kit would be a better idea. How can I order the right replacements and rebuild them. And I guess more importantly is this something a newbie can handle you think?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 03-14-2018, 12:23 PM   #2
flashed
Re: Drum brakes replacement parts?
You can reuse the springs ,just replace the shoes and wheel cylinders .
flashed is offline   Reply With Quote
Old 03-14-2018, 03:24 PM   #3
raidmagic
raidmagic's Avatar
Yes, certainly a job a newbie can handle. Clean it all up and paint it, throw on some new shoes and wheel cylinders if needed and move on.
raidmagic is offline   Reply With Quote
Old 03-14-2018, 04:45 PM   #4
JJ660
Do 1 side at a time. That way you can always look at 1 that is still together.
JJ660 is offline   Reply With Quote
Old 03-14-2018, 04:57 PM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
Rock Auto has all the replacement parts. Not sure what year you are working on, but here are the numbers for a 1965 C-10 with 11" x 2" rear drum brakes.
Drums: RAYBESTOS 2005R {#102005, 2005, F2005} Professional Grade; Outside Diameter 12.375" / 6 Bolts / Not Finned
Shoes: RAYBESTOS 280PG {#280RP, 280RR} Professional Grade; Organic; 11.00 X 2.00 (Same shoes used on front also)
Wheel Cylinder: ACDELCO 18E1123 {#18E444, 19175652, 89052214} Professional Rear - Right
Wheel Cylinder: ACDELCO 18E1124 {#18E443, 19175653, 89052213} Professional Rear - Left
Hardware Kit: CARLSON H7018 Drum All-In-One Kit
Newbie should be able to do it. Take your time and use you picture above as a reference. Should be plenty of You Tube videos to watch too.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
