![]() Join Date: Feb 2005
Fuel Sending line hook up
It's been awhile since I took the fuel unit apart. Now I need to know where do each of the FUEL LINES go. A goes to ??? B goes to ???? C goes to ????? and D goes to ?????????? Thanks, John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
Re: Fuel Sending line hook up
3/8 = feed
5/16 = return 1/4 = vent big pig goes to filler neck port on the side of the filler neck
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Thanks sweetk30,
So A is 3/8 = feed B is 5/16 = return, C is 1/4 = vent, and D is big pig goes to filler neck port on the side of the filler neck ( Breather vent ) if so then thank you very much. John
