LED License plate lights splice?
Have a couple of LED license plate lights. Each has a red and black wire coming out. I’m assuming red will be the lead that I should splice to the running lights (so they come on when the lights are on), and the black will go to ground. There is a green wire and a black wire going to each tail light. Any suggestions on which wires I should splice these suckers on to?
Thanks!! Erik
Slemmy "Annie" - '69 Chevy C10 396 "Louise" - '65 Chevy C10 6 Banger "Victoria" - '65 Mustang Notchback "Haley" - '62 Mercury Comet S-22 |
Re: LED License plate lights splice?
Slemmy, get yourself one of these https://www.harborfreight.com/circuit-tester-30779.html they are widely available and worth every penny. You can quickly use it to determine which wires are hot and which are grounds. I actually found mine to be so useful I bought a high quality one that even makes a beep when the circuit is complete for those times when it is difficult to view the light. (I.e. testing brake lights) As to your specific question on a vehichle, black is the factory color used to indicate a ground.
Green is the power feed for the taillights, black is the ground. I have them on my 65 GMC
