03-16-2018, 10:36 AM | #1 |
Crossmembers and Airbags
Getting close to getting the rear bag set-up done. We did some mock up work and looks like my drive line is going to hit the crossmember frame support. In your guys opinion, should I modify this one or do you know of a new center support that has more clearance? See pic with red arrow
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
03-16-2018, 01:49 PM | #2 |
Re: Crossmembers and Airbags
You may have to make one.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-16-2018, 03:26 PM | #3 |
That crossmember wasnt used on short beds so now that you’ve shortened the frame just remove it.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
03-16-2018, 03:48 PM | #4 |
My drop isn't a much as yours. I had to notch about 1/2 out of the cross member. So far so good...
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
03-16-2018, 03:55 PM | #5 |
That's what I was thinking also. thanks
03-17-2018, 09:24 AM | #6 |
Looks sweet! Are you raising the bed floor?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-17-2018, 10:31 AM | #7 |
I was planning to, but I left this one in and cut a section for the C-notch. That way I can mount the tank and compressors upfront and the gas tank in the rear. I think I will either put a new metal one in that is raised or a wood one.
03-17-2018, 10:34 AM | #8 |
I think I will leave the crossmember in for strength. I will use a piece of 6" pipe and weld it in the center of the member for clearance. Well..... that is the plan so far.
03-17-2018, 01:19 PM | #9 |
Sweet! Let me know if you need some of my shortened rear tubs.
