Wild idea
I have access to a 1981 c10 as a donor truck. I was thinking instead of swapping the power steering, front and rear ends into my 65 c10 maybe it would be easier to fit my 65 onto the 81 frame. Anybody have any insight in how difficult that may be?
Pat |
hillbilly
Re: Wild idea
I believe that your body will sit high on that frame. It will look like a 4x4
-1962 C-10 |
Re: Wild idea
I think the fame kicks up higher in the rear for the 1973+ models, and not to mention changing most if not all body mout locations. I think it raises the body 3-4 inches over stock by the time your done.
![]() Join Date: Sep 2006
Re: Wild idea
More work then just swapping front and rear.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Wild idea
This question has been asked many, many, many times and I still will try and discourage doing this swap. There is absolutely no benefit to all the work, and it IS and LOT of work. Take a look at this thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
Re: Wild idea
Thanks Captinfab. i have always valued and appreciated your knowledge and insight regarding these trucks. I just thought that by changing the cab mounts was a lot easier and less expensive than retrofitting newer front end powersteering upgrade tank reolacement etc.
Pat |
