![]() Join Date: Mar 2011
flowmaster 817654 stainless kit
anybody use this Stainless Kit and can give some advice or recommend I want to run shorty headers( maybe ) may go with long tubes.... not sure yet, on a 350 and want to put it thru the ECE dropmember run the mufflers top of trail arms and most likely out the back if someone has used this kit be interested and any pictures would be great
Here is the info right off their site 817654 Exhaust Systems / Kits - American Thunder® Crossmember back 409S - Dual Rear or Side Exit - Moderate/Aggressive Sound Fits 1967 to 1972 Shortbed/Longbed GMC and Chevrolet C10 and C15 1/2 Ton 2 wheel drive pickups with a V8 engine using the coil spring suspension only
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
New Member
![]() Join Date: Jul 2018
Re: flowmaster 817654 stainless kit
Old post but I’m also considering the flowmaster kit for my 68 C10 SWB with static 6-8” drop. I’d like to see side view pictures of the setup installed, looks like pipes run below part of the frame. If anyone with that Flowmaster kit can post some pictures of the exhaust I would be great full. I want to see if it hangs down noticeably low where it may be a clearance issue
#3 | |
