Old 03-17-2018, 10:26 PM   #1
tmills213
tmills213's Avatar
Turbo log manifold question
Should there be any concern about having the primaries straight out like this?? I started with elbow and it was a compound angle PITA. I see the dirty dingo ($$$$) log as the only reference which used straight primaries... will I be fine.
pipe is 1.5 and 2.5" sched 40
tmills213 is offline   Reply With Quote
Old 03-18-2018, 12:24 PM   #2
davepl
davepl's Avatar
Re: Turbo log manifold question
It's not ideal, but it won't cause any problem that I can think of. I mean old iron log manifolds aren't that much better internally sometimes.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-18-2018, 12:46 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Can you just set the log back a little bit and set the primaries on a low angle? What you want to avoid is the air getting forced out directly into the wall of the tube at a 90* angle.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-19-2018, 02:01 PM   #4
tmills213
tmills213's Avatar
when I started with the elbows, the elbow was getting so short compared the to the ID that it was essentially straight. I am also basing my judgments off others i see. does that make it right. no. sigh. I wish i wasn't so cheap
Old 03-20-2018, 09:42 PM   #5
AZ 67 C10
AZ 67 C10's Avatar
Turbulence in your manifolds is a big part of how efficient your turbo is. What you have will work but isn't ideal
AZ 67 C10 is offline   Reply With Quote
