fr. air bag,need a spacer ?
I need to put a 1 inch spacer in the front air bags on a 78 , do I have to separate the lower ball joint or can I squeeze it in.
Diggin The SquareLife
Re: fr. air bag,need a spacer ?
spacer for what reason
If you let your suspension hang and disconnect your fittings you should be able to muscle it in.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
thanks, I had a 2 inch spacer but was too much and took it out but now I need 110 lbs. for ride height so I will cut it in half and try that. No compressor hooked up and last year I tried to release the ball joint it didn,t want to with out some pressure pushing on it. Plus I hate wrecking dust boots. Waiting for spring, long winter this year
