Old 03-18-2018, 09:49 PM   #1
chip46wis
metal to wood boards shorter?
I am going to put a wood bed over my steel bed in my 1972 factory SWB.Are the boards shorter than stock boards? my concern is for tailgate clearance. TY
chip46wis is offline   Reply With Quote
Old 03-18-2018, 10:32 PM   #2
harpo231
harpo231's Avatar
Re: metal to wood boards shorter?
What boards ? You got the boards already ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-18-2018, 10:45 PM   #3
Old_Gold
Old_Gold's Avatar
I have not seen a wood over steel bed, but the boards should the same length, as the tailgate drops in behind the bed surface. The wood will make it taller than the tailgate when open, but the same length should work.
Hope that answers your question, and post a pic when you're done!
Jim
Old_Gold is offline   Reply With Quote
Old 03-19-2018, 12:16 AM   #4
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Have you seen Show Beds? They lay on top of your steel floor on a frame and can be removed in no time. The cross braces lock like your fingers in a prayer position if that makes sense. Seen this on Stacy Davids Geazs TV show.It looked to be about 3/4 inch thick.With thetailgate up you could not tell it was not stock.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 03-19-2018, 12:24 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
If money is no object you could always install a "Showdeck" system over the steel floor....
http://www.horkeyswoodandparts.com/page2.php
LockDoc
Leon
Old 03-22-2018, 08:29 PM   #6
chip46wis
Ty
