Old 03-19-2018, 12:29 AM   #1
Railroader
Railroader's Avatar
Ball Joint Shaft to Spindle
Anyone know what the torque level should be on upper and lower ball joint shaft to spindle?
Also has anyone have experience using wheel spacers? I need about 3/16 inch clearance for my steel rims to clear disc brake calipers.
Railroader is offline   Reply With Quote
Old 03-19-2018, 06:55 AM   #2
PGSigns
PGSigns's Avatar
Re: Ball Joint Shaft to Spindle
I have always just pulled them up good and tight and then tightened them just a bit more to get the castle nut to line up wit the hole in the ball joint so the cotter pin will go in. I have used steel wheel spacers in the past with no problems. What you need to do is make sure the center up good and when the wheel goes on there are threads sticking out through the nuts. You may find the studs are a little short.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-19-2018, 05:18 PM   #3
Railroader
Railroader's Avatar
