![]() Join Date: Feb 2009
TWO Western Turbine Wheels, 16.5 x 8.25 - 8-Lug
No longer for sale, thanks.........
You can have the pick of five, they're all legit. I'm using a pair myself after the rubber burns off the 9.75" turbines currently on the rear of my truck. A lot on my plate right now, so I very much prefer to sell these locally only. $140 for the pair. Thanks.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-01-2019 at 10:10 PM. |
Re: TWO Western Turbine Wheels, 16.5 x 8.25 - 8-Lug
ttt
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jan 2007
Still got them? I need at least one.
Do you mind shipping to California? I’ve had luck with uhaul boxes... Thanks Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Hi Old Creek. Change of plans, I'm sorry. Turns out there are at least two different turbines. One takes a push-through hub cap, the other version mounts the cap with lug nuts, which are the wheels on my truck. I "need" the push-through type, which were the one's I was selling. I'm switching them out when the rubber burns of the 9.75x16.5 rear turbines.
If interested, at some point I'll lose what's on the truck.....Fronts are 8.25 turbines (nut-on cap).
I’m running the 8.25 on my blazer.
Mostly, I just want a matching spare. Would you pm me when the time comes and let me know what you’re letting go of? Thanks, Wil P.s. pics of my wheels and blazer in my member section
Will do Wil
![]() Join Date: Jan 2009
I could use one or two 16.5 9.75 turbines. One of mine is cracked
Noted.
