Swb 72 GMC frame f/s
$1000.00
i have 67/72 chevy truck parts f/s. |
Re: Swb 72 GMC frame f/s
It comes with a lot of new parts
It has new ss lines and new rubber hoses ft and rear new brakes in rear.
Most if not all of it is there.
What gear ratio in rear? Is it a Posi?
I am not sure on that may have to pop the cover off 1 warmday & check it out
It also comes with a newly powder coated ft. Sway bar.
![]() Join Date: Mar 2011
close up pic of rust in rear is it deep pitted or surface...and would you consider parting just the frame the way it sits ... if so what would be your best #
thanks jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
I will look it over again but I think only rust is surface.
If you can verify gear ratio and check shipping to 77830, I would be interested in the rear differential.
We are getting 5 to 8 inches of snow tonight. I will try and get to it in a couple days when it's a little Warner. I don't have any way of shipping something that big and heavy.sorry
Jz pm me your phone #& I can text you a couple more pictures. The rear 1/3 of frame has just a little more surface rust it's like surface rust times 2 not bad at all.bill
#13 |
Pic
#14 |
The last 1/3 of frame is starting to pit some.see pics I will take $600.00 for VB frame only.its still in pretty good shape.
#15 |
Pic
#16 |
Pic
#17 |
Last 2 pics is of the rear end still don't know size but frame with it had a v8 & auto trans
#18 |
Would take $450.00 for rear end. It's had all new brakes and lines and hose and stuff.
#19 |
sent you a text thank you good luck with the sale
#20 |
#21 |
Reasonable offers
#22 |
I'm interested. I'm trying to get my son and his buddy to go down and check it out. It's only a four hour drive. I work odd hours and days. PM me your phone number and I'll call you. Tom
#23 |
Sending you a pm .
#24 |
Pic
#25 |
Pic
