Old 03-21-2018, 10:30 AM   #1
ChadW
Not bad for a rookie....
Working on a 66 fleet and this is my first shot at metal work/rust repair etc...I feel pretty good with how this pan and kick panel turned out...holes line up perfectly on the floor support etc...got it all cut in tight and now its ready to weld..the repop floor pan was not even close on the firewall side pinch weld area so i beat it flat and broke it over where it needed to be..was relieved when it all fit together well..
ChadW is offline   Reply With Quote
Old 03-21-2018, 10:34 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Not bad for a rookie....
Very good work there.
Old 03-21-2018, 11:35 AM   #3
Robert Haas
that should work. remember to POR the crap out of the areas you can not do after you weld it together. The new parts will rust out in a few years if you don't
Robert Haas is offline   Reply With Quote
Old 03-22-2018, 08:59 PM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice work man, you are a natural.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-22-2018, 10:34 PM   #5
64 rust
64 rust's Avatar
Looks great!
64 rust is offline   Reply With Quote
Old 03-23-2018, 09:50 AM   #6
ChadW
Once i get it all welded up and before i put the outer rocker on, how should i treat the new metal? I was thinking red scotch brite and then hit is with some primer...Is there an epoxy primer i can get in a rattle can, or anything i can use in a rattle can just to protect it for now...Once all body/rust repair is done, everything will get sprayed the right way..
Old 03-23-2018, 11:36 PM   #7
Captainfab
60-66 Nut
I see no reason to prime it now and then having to remove it all later to apply some 'good' primer. Unless you are going to leave it outside in the rain.
Old 03-24-2018, 08:14 AM   #8
ChadW
No sir...shes inside the toy garage 100% of the time....should i coat the inner rockers with something before covering with the outer?
Old 03-24-2018, 09:44 AM   #9
LT1 Burb
LT1 Burb's Avatar
Nice job, do not POR15 anywhere you need to plug weld.
LT1 Burb is offline   Reply With Quote
Old 03-24-2018, 12:05 PM   #10
silvertonguedevil
silvertonguedevil's Avatar
I'm curious about this as well.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 03-25-2018, 01:28 AM   #11
Captainfab
60-66 Nut
The factory e-coat is pretty tough, but you could coat the insides with either an epoxy primer. POR15 or a similar quality coating. But as LT1 Burb said, do not coat where you are going to weld. Also Eastwood makes an aerosol can with a flexible tube that is designed to be used to coat the insides of cavities for rust protection.
Old 03-26-2018, 10:24 AM   #12
ChadW
More progress...replaced a small section of inner that had a little rust on it and got it tacked in as well.. got the kickpanel cut to fit and lower front piller cut as well.. the kick panel was pretty much gone where it meets the floor pan so I hope it goes back together as its supposed to...it gets confusing sometimes because multiple replacment parts have the same pieces on them...gotta figure out what i need and what can be cut off etc..
