Old 03-21-2018, 11:52 AM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Dana 60 Hub Removal Video
Hope this helps some of you.
Main thing was getting the right tool
http://amzn.to/2FRz3MS
68SWB4x4 is offline   Reply With Quote
Old 03-21-2018, 08:06 PM   #2
sweetk30
sweetk30's Avatar
Re: Dana 60 Hub Removal Video
do not need to tear apart whole locking hub . 1 center snap ring off stub shaft and 1 out of the hub/rotor body . then 2 hub screws in to let you pull on them and pop out hub complete .
drive the caliper wedge the other way next time . much faster and easy to swing the hammer .
the socket you didnt like is the better one in my opinion . the second one if not careful can break the little tiny pin off on the inner nut and screw you on a sat/sun when no body has that part . so watch your self .
the snap ring pliers will pull the lock ring out and help install a lot better also if you have trouble getting it to move in there . and FYI: the lock ring holes are off set on the tabs location . so if off by a hair of lining up the inner pin to the washer hole flip it over .
last trick - put the outer nut on a few good turns . then pull the hub/rotor down and out . the nut will catch the bearing and use it to pop the wheel seal out and not hurt the bearing . make removal super easy and you wont need a seal tool or prybar .
good job on the video . these are just my few tips to help others later .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-30-2018, 05:59 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Appreciate the advice for next time.
Lots of good tips
Old 03-30-2018, 08:32 PM   #4
sweetk30
sweetk30's Avatar
no problem . i have had prob over 1 dozen my self and worked on about as many .
