11-08-2003, 06:26 PM | #1 |
canister vs. screw on oil filter
here's another stupid question guys and gals...went to Napa today to grab an oil filter, my truck has a 350 with the canister type oil filter. the guy looked up '69 GMC in the filters manual, and it gave the PN for a screw on oil filter. I just had him get the PN for a '68 GMC, since it was the canister type. My question is this, when exactly did they stop using the canister type oil filter? Last time I went to the same Napa, the store owner looked up '69 GMC, and went and grabbed a canister filter off the shelf. One of the parts store regulars (those old guys that are always standing around in there) said that my engine "had to be from a '63 or earlier car or truck" because that is when they stopped using canisters, but I think he's wrong. Maybe I should just check Mortec, to see if I really do have a 350 and not something else, that would be indicated by the canister oil filter. Phew, sorry for the length, any info would be appreciated.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
11-08-2003, 07:32 PM | #2 |
My 68 Chevy 327 was a cannister type. (I Want to go back to cannister someday) I don't remember where I heard this but I think that many chevy cars went to spin-on around 68. The trucks stayed with cannister until around 69-70? That's my understanding though it's not based on hard facts.
Perhaps you could make the assumption that MOST small journal small blocks were cannister type and MOST large journal small blocks were spin-on. The exception would be trucks which carried through a couple of years later with the cannister.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
11-08-2003, 08:00 PM | #3 |
I'VE HAD EVERY YEAR (67-72) & EVERY ONE HAS HAD A SPIN-ON OIL FILTER, BUT SINCE I DIDN'T BUY ANY OF THEM NEW, I CAN'T SWEAR THEY CAME FROM G.M. THAT WAY.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
11-08-2003, 08:15 PM | #4 |
the 67chevy overhaul manual shows a spin-on type filter
11-08-2003, 09:24 PM | #5 | |
11-08-2003, 10:57 PM | #6 |
Pennyless Fool
My 67 was canister, just converted it to spin-on.
11-08-2003, 11:04 PM | #7 |
He's got mean nasty FANGS!
From everythign I've seen, almost all V8 trucks from 67-69 had teh cannister type. The striaght sixes had spin ons, some mid to late 69 V8s may have had spin ons also.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
11-09-2003, 03:00 AM | #8 | |
thanks for the responses guys, keep em comin
11-09-2003, 05:06 AM | #9 |
Never too many LONGHORNS!
I had a 1969 Chevy truck that had a 396 engine with a cannister type and another 1969 Chevy truck that had a 307 engine with a cannister type.
Hope this helps |
11-10-2003, 03:24 AM | #10 |
T T T
11-10-2003, 03:30 AM | #11 |
Formerly yellow72custom
One of my friends had a '67 C10 with an original 283....and a cannister oil filter.
I would run your numbers 1969 GMC....at least get the suffix code (2-3 letter code on a machined pad on the block infront of the passenger side cylinder head), and run them at www.nastyz28.com . Mortec.com dosent' have the suffix codes anywhere that i could find on their website.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-10-2003, 12:36 PM | #12 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
11-10-2003, 06:37 PM | #13 |
Lucas...where exactly is this pad? Can I see it with the engine in the truck and the manifolds on? I looked but couldn't find anything.
Palallin-i guess it just depended on what the assembly plants had sitting on the shelf. In '69 they were supposed to switch to the 205 but not all did.
11-10-2003, 07:00 PM | #14 |
Here ya go Adam....i circled the pad in yellow. It is proably covered with grease....wipe it off and the letters are usually the last charcters stamped on the pad.
11-10-2003, 08:36 PM | #15 |
thanks man...i came up with a TJM, which translated to a 73-74 350 from a bus? odd that it would have a canister still.
03-18-2020, 08:16 AM | #16 |
Re: canister vs. screw on oil filter
So what is the consensus opinion on doing the conversion from canister/cartridge filter to spin-on filter? I converted my 327 (‘66 C10) to spin-on many years ago and I now wonder if I did the right thing. Other than nostalgia or “concours restoration” are there any arguments for keeping or, in my case, returning to the original canister/cartridge style oil filter? Any arguments for the spin-on filter being the better choice?
'66 Custom Cab BBW SWB Fleetside 327/TH350 Factory A/C ‘96 Dodge Ram 2500 Laramie SLT Club Cab 4X4 8’ bed V10/47RE |
03-18-2020, 08:31 AM | #17 |
03-18-2020, 08:36 AM | #18 |
Old member
All my trucks have spin on's. The 71 had it from factory. The 68 I just sold I swapped it to a spin on. I prefer it over the mess canister make.
The ramp truck has a spin on but it's not the motor that came in it. It's a Corvrtte motor 350 per the old owner! Which by the way could be it had the corvette ram-horns on it when I got it. They are now on the 64 SS Impala though. To answer your question I like the spin on filters much easier to do a change than the canister and not near as messy!
03-18-2020, 08:51 AM | #19 |
Who Changed This?
I've changed 1000+ oil filters in my years as a mechanic. Picking that o-ring out of the block on the canister type filters is a time-consuming pain in the neck. I prefer the spin-on.
03-18-2020, 09:03 AM | #20 |
My 67 has been converted to spin on (283). Funny thing is three of the four toyota's I have are canister type. Go figure.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
03-18-2020, 09:59 AM | #21 | |
Steeveedee, your account/experience has thoroughly convinced me I did the right thing. Thanks to all of you for your responses.
03-18-2020, 10:35 AM | #22 |
I wanted to keep my canister so I did this little modification. I can drain the canister in about 10 minutes before I remove it.
03-18-2020, 12:02 PM | #23 |
That is a great idea and some good work. If I hadn’t already converted mine, I would definitely be giving that a shot.
03-18-2020, 09:59 PM | #24 |
03-19-2020, 06:48 AM | #25 |
Or you could go with this. (Might be a bit tough in this day and age!)
