Did I get the wrong axle seal?
The new seal is the one with red. Its what the parts store says is needed for my truck. Its a 12 bolt non posi. It looks like that silver ring thats still in the hub just needs to come out and the new seal will fit but I just want to make sure so that I don't ruin something.
1968 C10 |
Re: Did I get the wrong axle seal?
No, that's the bearing outer race. That needs to be pushed in further and then the seal will fit into the axle bore.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
#3 | |
1968 C10 |
#4 | ||
"I ain't nobody, dork."
Huh... never seen an outer axle bearing like that in a truck 12 bolt. There is no "race" that I've ever seen. The bearing and "race" is a single caged unit.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
That looks like an axle-saver bearing. It is located outboard a little to run in a fresh location on the axle. You may need a different seal than the stock replacement.
Yeah it is, I found another locally and so far no more leak.
1968 C10 |
#7 | |
The Older Generation
LockDoc
#8 | |
Lets see the box it came in for a part number (bearing AND seal), then we can help you perfectly.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I already finished the job. Instead of trying to locate a seal that would fit into that axle saver bearing I Just bought a whole new axle saver bearing.
1968 C10 |
I assume it installed exactly the same way? Because of the step in the housing I wouldn't think it could go in the other way.
That is correct.
1968 C10 |
