![]() Join Date: Oct 2013
WTB: Eaton "NO-SPIN" from HO 52 or 72
Want to buy a Eaton HO52 or 72 No-Spin, if with gears ok too. Prefere 4:11.
Thanks, Les |
Re: WTB: Eaton "NO-SPIN" from HO 52 or 72
I've got one ...i gave $350 for it so I'll take my money back to. A member
![]() Join Date: Nov 2005
I have one of these in my 1972 k20 suburban. The code on the glove box is. 1G8610. I'm sure the experts amoung us can tell if that's correct for Eaton no spin 4:10 ratio. It's in a running driving currently daily used truck. Gears don't howl or anything like that. Sometimes turning a sharp corner it will pop. So clutches are grabbing a little. Used to use whale oil in corvettes to fix same problem.
I'm close to the guy in Louisville , about 100 miles. I want to sell whole diff. Drum to drum. $500 Questions. Art. 317-750-0065 |
![]() Join Date: Mar 2017
52 NAPCO- Do you know what this came out of? Mileage? What comes with it? Pictures? How close are you to Charlotte? Thanks.
BNTMOTORCYCLES - That number shows up as a 10 bolt front diff with a locker. How sure are you that it's a Eaton? Mileage? Thanks
Isn't the G86 the code for- "Axle Rear, Limited Slip"?
Thanks NAPCo. I need the 4.10 gear, too.
I stand corrected. The problem is what gear is in it? 4.10 or 4.56?
I'm no expert but from references like this;
http://outintheshop.com/options.html early rpo codes translate to; G86 no-spin, gm trade name for locker, typically Eaton G80 positrac, gm trade name for limited slip, typically Dana from my understanding, 72 was the last year for HO52/72, 14 bolt corporate replaced them in 73.. G86 lockers in those were called gov-lock [governed locker], also affectionately known as gov-bomb ![]()
I started out with nothing - and I still have most of it |
Upon further investigation, It appears the G86 code applies to both the 4.57 and the 4.10. In a K20 with a V8, the 4.10 was standard and the 4.57 an option so if it is a 4.57, it should show as an option on the glove box door. Now... I have no idea if this is the same on a Suburban. Just to be clear, I'm looking for a 4.10. Thanks for the help.
Now I'm confused, how about everyone else. It's definitely an Eaton, it is a posi and it drives like a 4:11. I haven't pulled the cover , I still drive it. I'm sure it's orig. to the truck. Never heard of a 10 bolt front posi from the factory? But I sure don't know everything about these trucks. Mileage wise I'd say 100,000 plus but I don't really know. I'll try to answer any other questions. Mainly I wanted the guy in Louisville to know one was close. He could drive and try it to see what he was really getting for his money. Other wise who knows till you've installed it. Art
#13 |
bnt,
K20 suburban most likely has 4.10 from the few I've seen.. a little hint to checking a factory gear ratio on a running truck.. the front is most likely a D44, Dana put ratio tags on the outside of the cover.. if it's original ratio, front and rear would be the same.. the Dana front will likely be 4.09 with a 4.10 Eaton rear.. although not required to be there, if it has the oval metal tag on the pinion cover, that denotes locker installed.. although the tag has no markings or stamps on it, the presence of the tag is the tell.. the locker 'pop' is normal.. here's how they work.. good, brief video worth watching https://youtu.be/AuZqG7pTabw if you pull the cover to verify for someone, the Eaton ring gear stamping will express the ratio by tooth count.. hope that helps! Dana 44 front of 71 K20 Suburban with Eaton HO52 4.10 rear ![]() Eaton HO52 4.10 ring gear ![]() Eaton HO52 locker tag ![]()
#14 |
I got the 1o bolt front dif from Googling the RPO number. I dug deeper to find that it does mean rear anti spin option that comes with ether gear. Thanks for all the info and pictures Killer Bee
