03-25-2018, 08:07 AM | #1 |
Jack hold down color
I’m at the point to paint and install the spring jack hold down near the rear inside tire carrier on a 71 Blazer. What was the correct color to paint it from the factory? Black.
03-25-2018, 08:26 AM | #2 |
Carpe manana
Re: Jack hold down color
Here's a photo taken from a survivor. At least on this example the components appear not to be painted at all: http://67-72chevytrucks.com/vboard/s...93&postcount=7
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-25-2018, 08:32 AM | #3 |
Thanks for the reply Pete. I think I will powder coat it silver to simulate raw metal and will show up a little since my carpet is black.
03-25-2018, 08:42 AM | #4 |
Carpe manana
I had mine clear zinc plated and I'll bet it's shiner than it ever was new. Also now that I look closely the spring appears black. If I tried again I'd soak it in Evaporust - that might bring back an appearance close to new. Powdercoat would look nice.
03-25-2018, 02:44 PM | #5 |
I have two sets and soaked them in evaporust. Remnants of body color paint were on them. Don't know if both the vehicles they came on had been repainted or were painted at the factory. I'll probably paint the set I'm going to use satin black.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 04-03-2018 at 03:08 PM. |
04-03-2018, 03:11 PM | #6 |
Here are a few photos
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-03-2018, 10:23 PM | #7 |
Carpe manana
Thanks for posting. Is the rear bracket painted? The front brackets are the same color as the floor pan with the rare exception being St LouisHighlander's that had white paint on the step face (and rear wheel tubs) in which case the these have white overspray. The rear bracket and spring look to be unpainted on the example in the above link.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 04-03-2018 at 10:31 PM. |
04-04-2018, 07:36 AM | #8 |
Yes all the pieces including the springs were painted in the two sets I have. Most of the paint sloughed off when I wiped them down after pulling them out of the evaporust, but you can see it
