Old 11-08-2003, 08:40 PM   #1
72bigblock
putting a 4x front axle under a 2x
hi all i am thinking about putting a 4x front axle under my 72 2x. the front of my 2x sits too low my push bumper is only 8" off the ground. thanks chris
72bigblock is offline   Reply With Quote
Old 11-09-2003, 01:27 AM   #2
72bigblock
ttt
Old 11-09-2003, 01:39 AM   #3
Hutch
Hutch's Avatar
Chris
A little more information please.
Do you want to covert a 2 wheel drive to a 4x4 or just raise the front of the truck?
Is your truck a 3/4 ton?
Was the truck an original big block?
Does your truck have rear leaf springs?
A big block truck with a heavy front bumper may sit a little low and you may be able to do something with heaver springs.
My understanding is that they require stronger springs.
To install a front axle from a 4x4 would require you to go to front leaf spings which would require spring perch's to be welded to the frame.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 11-09-2003, 02:18 AM   #4
cableguy0
check out fabtech they make lift kits for 2wd trucks which would be the easiest way to go a 4x4 axle put on a 2wd frame is a pain in the nuts avoid the hassle and just lift it with a good kit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
