WTB Big Block power steering pump and reservoir
Looking for a power steering pump and reservoir for 1971 402 big block. Let me see what ya got.
![]() Join Date: Mar 2010
Re: WTB Big Block power steering pump and reservoir
I will look and see what I have. Hopefully I can help you out. Thanks
#3 | |
Always on the hunt...
![]() Join Date: Sep 2006
![]() $125. / BBC p/s pump and fender reservoir. (no mounting brackets or pump pulley) $175. / BBC p/s pump, fender reservoir and pump pulley. (no mounting brackets) $275. / BBC p/s pump, fender reservoir, pump pulley and both mounting brackets. |
Last two pics...
#5 | |
![]() Join Date: Aug 2013
Okay, we'll stand by for his reply back, he could also end up purchasing the needed parts from daddymoo2. We are getting ready to post a multi item 72 big block parts F/S thread on the parts board and will add these BBC power steering parts to that thread should BLT-NT-BOT pass, will place you inline. Mel
BLT-NT-BOT: Here are the pics. Thanks Off 72 402 Asking 260.00 Shipped. Thanks Don
Per our earlier phone conversation, here are the A/C brackets that we can pull from that same big block truck. Will offer the pictured 9 pc. BBC A/C bracket setup to you for $275. if purchased along with the other offered big block P/S parts. Thanks, Mel
With the bracket setup still installed it's kinda hard to tell what you will be receiving, here is a picture of another (previously sold) 9 pc. BBC A/C bracket setup. After removal, you would be getting these nine pump mounting brackets, a lot of guys run this big block setup as a 7 pc. without the two pc. rear brace rod and manifold bracket (see red arrows). The compressor will mount and be supported fine without these two braces, if you want to go with a 7 pc. bracket setup, we will go $245. w/o the two marked braces. Mel
#11 | |
Thanks Jothan |
![]() Join Date: Dec 2015
Don't want to hijack the thread.
Mel, I'd be interested in the two brackets you have circled in red above if you decide to separate from the others. PM me if you'd like. Thanks. |
