Old 03-25-2018, 06:20 PM   #1
67shortstepside
Gas pedal help !
Hey guy this is my first truck build . Does anyone have pics of how the gas pedal mounts to the floor of the cab ? Thanks
67shortstepside is offline   Reply With Quote
Old 03-25-2018, 06:45 PM   #2
ga-stepside
ga-stepside's Avatar
Re: Gas pedal help !
There are a couple studs with round tops that bolt to the floor and the pedal snaps onto those. Like this:
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 03-25-2018, 06:58 PM   #3
67shortstepside
Do you have fire wall pics ?
Old 03-25-2018, 07:06 PM   #4
dec010974
dec010974's Avatar
i switched to a regular, later, 1971 c10 and up pedal.
dec010974 is offline   Reply With Quote
Old 03-25-2018, 07:25 PM   #5
ga-stepside
No sorry, I actually found that pict by searching.
1967 C10 Step side
1970 AMX 390
Old 03-25-2018, 07:33 PM   #6
Damien8086
I cannot for the life of me remove the pedal studs from the floor. The left side stud ball has broken off and the nut part of both studs doesn't really look like a nut anymore.
Is there some trick to removing these things so that I can replace them?
Damien8086 is offline   Reply With Quote
Old 03-25-2018, 08:03 PM   #7
ga-stepside
I had trouble getting mine out too. There is probably a ton of rust on the threads. Spray the hell out of them with penetrating oil and let it sit for a day. Put some vice grips on them if you can, and try slowly turning them. I've found alternating from loosening a little bit back tightening a little and so forth helps until they free up. Failing that hit them with some heat but clean off that oil, you don't want fire! Or cut out the old plate which I think is welded to the floor, get or make a new plate, weld or bolt that to the floor and get new studs.
1967 C10 Step side
1970 AMX 390
Old 03-25-2018, 10:04 PM   #8
'70_402
'70_402's Avatar
If you switched from a factory 67 throttle rod assembly to a 71/72 cable assembly, you'll need this adapter.
http://67-72chevytrucks.com/vboard/s...d.php?t=746099
'70_402 is offline   Reply With Quote
Old 03-27-2018, 12:09 PM   #9
Damien8086
The threads on the studs don't even appear to be visible in order to grease them.
I did saturate the studs hoping some might make it to the threads a few times and let them sit overnight and they're still not budging with vice grips.
I am thinking I might try and cut a deep enough slice in the center of one and see if I can get a flat-head screwdriver in there, but I am not feeling optimistic that it'll turn.
Old 03-27-2018, 12:13 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
You can also tack weld a nut to the stud, by welding inside the nut.
Some times the heat from the welding will also loosen the rusted threads.
Keith
Convert to disc brakes.
Old 03-27-2018, 12:56 PM   #11
ga-stepside
Good idea. But like me he may not have access to a welder
1967 C10 Step side
1970 AMX 390
Old 03-27-2018, 01:01 PM   #12
Damien8086
Correct, no access to a welder nor any experience with welding
Old 03-27-2018, 01:14 PM   #13
demian5
demian5's Avatar
Grind them off if you don't need them.
If he doesn't have access to a welder or a grinder, he will have to pony up or borrow something. If you just break them off, the carpet will cover the remnants.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-27-2018, 03:54 PM   #14
Damien8086
I do need them, just trying to replace them with new ones because they're in pretty bad shape, but can't get them off
Old 06-10-2020, 07:36 PM   #15
STPETEBLUE
STPETEBLUE's Avatar
Has anyone had any luck? Mine are little tiny points. I'm looking for a solution, too.
Daily Driver:
2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed
Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded).
STPETEBLUE is offline   Reply With Quote
Old 06-10-2020, 08:40 PM   #16
LockDoc
The Older Generation
LockDoc's Avatar
If you can get any kind of wrench or grips on them try heating them up as hot as you can with a propane torch and let them cool back down a little, then hit them with some penetrating oil. Do this two or three times then try removing them. The heating and cooling will break the rust bond in the threads. If that doesn't work or you can't get a hold of them to turn them you will just have to cut or grind them off flush, drill and tap new holes and screw the new studs in. I don't know if the new studs are long enough to put nuts on the bottom side or not.....
LockDoc
Leon
Old 06-10-2020, 09:53 PM   #17
Smitty
Smitty's Avatar
If you have to drill them, try to get as close to center as possible. Try starting small and step drill up to the tap size bit. The tap may clean the old material out. And not mess up the original threads. Or once you get a hole through, it may relieve some of the pressure from the threads. Allowing you to remove it with an easy out. Good luck.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-10-2020, 10:21 PM   #18
STPETEBLUE
STPETEBLUE's Avatar
LockDoc
Thanks. All I wanted to do was replace the ball studs and put a gas pedal on it. Now it looks like I'll be pulling up the mat, insulator and soundproofing to do this.
It would really be nice if I could just mount the '71-'72 pedal only on the linkage.
Daily Driver:
Old 06-10-2020, 10:30 PM   #19
palallin
When you drill, use left-handed bits and a reversible drill motor. The bits might catch and turn out the remains of the studs.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
