Old 03-25-2018, 09:04 PM   #1
71gmcC15
71gmcC15's Avatar
Unkown connecter
I have 3 wirs running along my driver side intake of my 71 gmc c15. Non AC and they are not pluged into any thing. I tryed to trace them back but go behide the motor and Ts into more wires any one know what its for. The wire colores are plain brown, brown with a white strip, and blue ( maby green)
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 03-25-2018, 09:05 PM   #2
71gmcC15
71gmcC15's Avatar
Re: Unkown connecter
Wires
Old 03-25-2018, 09:06 PM   #3
71gmcC15
71gmcC15's Avatar
End of conneter
Old 03-25-2018, 10:27 PM   #4
Redneck Rydes
Redneck Rydes's Avatar
Kinda looks like a alternater wire.
Redneck Rydes is offline   Reply With Quote
Old 03-25-2018, 10:35 PM   #5
Acorn
Alt was my first thought too.
See if this helps http://67-72chevytrucks.com/vboard/s...d.php?t=185856
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 03-25-2018, 11:52 PM   #6
71gmcC15
71gmcC15's Avatar
Thanks for the fast replies. I thought that to but the alt is hooked up and works. And its too short to reach. Could it be for the orignal choke of a 2bb carb. I know they usealy only have one wire. Not shure what the choke wire even looks like for a 2bb . Mines not hooked up and swiched to a qjet.
Old 03-26-2018, 03:43 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Your description sure sounds like the pathetic emissions control the 70 and 71 models had that was called the transmission controlled spark. The plug with the two browns and the blue wire were plugged into a vacuum switch on the carburetor that would retard the timing
when engine vacuum was low.
Most of the trucks from that era had these systems disconnected because they did nothing and removing them never hurt anything.
You should have a couple of relays on the firewall or over the fuse box with wires running to them as well.
if you do a search on the forums for Transmission controlled spark, you should get more information. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-26-2018, 08:25 AM   #8
71gmcC15
71gmcC15's Avatar
Thanks. That helped out alote. I will just leve the wires alone then. Its simpler that way. I did not know they had somthing like that. Good to know.
Old 03-26-2018, 12:48 PM   #9
71gmcC15
71gmcC15's Avatar
time to play round two.
i dont have a photo of it yet i will get one soon but on the right side their is a single light green wire with a connection the same as the temp sender (dark green). i think it could be the original choke wire but it does not work with my qjet. the carb is off of an 80s chevy. hense the reason its the choke not hooked up. any one have an idea on what it could be.
Old 03-26-2018, 01:12 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
'71 did not have an electric choke. Is it a two-prong jack, with the other wire color as black? If so, it would be for the AC compressor.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-26-2018, 02:31 PM   #11
71gmcC15
71gmcC15's Avatar
thanks for the replie Single prong female end only one wire, light green. No electric choke? did it have a thermal choke then? i do not have AC so that cant be it
