Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-26-2018, 12:41 PM   #1
NJ C10 Guy
Lunati 06108 Cam
$50 + shipping to your door
For sale is a used Lunati 06108 cam I pulled from my 350 when it spun a rod bearing. The motor was shut down immediately and disassembled. There are no wear marks, scratches, or worn out lobes. If you want to see additional pictures let me know and I'll do my best.
Here is a link to the cam card from Lunati:
https://www.lunatipower.com/CamSpec.aspx?p=06108
Here are manufacturer's specs:
Brand: Lunati
Manufacturer's Part Number: 06108
Part Type: Camshafts
Product Line: Lunati High Efficiency Camshafts
Summit Racing Part Number: LUN-06108
UPC: 090127456033
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 218 int./218 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 268
Advertised Duration: 268 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.457 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.457 in.
Valve Lift with Factory Rocker Arm Ratio: 0.457 int./0.457 exh.
Lobe Separation (degrees): 110
Computer-Controlled Compatible: Yes
Grind Number: HI-268
Valve Springs Required: Yes
NJ C10 Guy is offline   Reply With Quote
