03-26-2018, 03:04 PM | #1 |
disc conversion on 76 c10 Brake Booster question
Would like to convert to disc/disc system. Can anyone recommend a store/manufacturer to get a new power brake booster and master cylinder from?
03-26-2018, 06:56 PM | #2 |
Re: disc conversion on 76 c10 Brake Booster question
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
03-27-2018, 10:00 AM | #3 |
Hi!
03-27-2018, 10:12 AM | #4 |
performance online sells a kit that has a new booster and master.
https://www.performanceonline.com/19...ster-Cylinder/ |
03-27-2018, 11:43 AM | #5 |
Will check it out. Thank you
03-27-2018, 12:11 PM | #6 |
I will add one thing. Be forewarned that the fitting on the rear brake line coming out of the factory prop valve is a very odd size and basically impossible to adapt to something common. I am running in to this problem currently. The only option i have found is to cut off the old line nut, and reflare a new common size nut onto the line.
