Old 03-26-2018, 08:50 PM   #1
2500HD
2500HD's Avatar
ZZ454 - Sniper - 4L80E - Compushift
Just completed the install. My buddies Chris and Phil did all the work and i just did what they told me to do.
Engine - ZZ454
Trans - 4L80E
Fuel Injection - Sniper
Fuel System - Holley in tank retro kit
Fuel tank - Boyds
Gauges - Classic Instruments
Accessories - Factory
Still working out the bugs but it is getting close
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 03-26-2018, 08:52 PM   #2
2500HD
2500HD's Avatar
Re: ZZ454 - Sniper - 4L80E - Compushift
More pictures
Early Classic 4.5/6
Old 03-26-2018, 08:55 PM   #3
2500HD
2500HD's Avatar
More
Early Classic 4.5/6
Old 03-26-2018, 09:08 PM   #4
Fraud
Looks good! I'd love to know how this all works out..
Any reason to go holley sniper + standalone auto controller vs. Holley Terminator with the transmission control option?
Did you swap to an electronic speedo or get a mechanical speedo output for the 4l80?
Any modifications needed to the column shifter?
Fraud is offline   Reply With Quote
Old 03-26-2018, 09:15 PM   #5
Mike's money pit
That looks great!
Mike's money pit is offline   Reply With Quote
Old 03-26-2018, 09:20 PM   #6
2500HD
2500HD's Avatar
I had the Compushift left over from a previous truck. I used a Lokar shift rod and put an OD lens in. The standard shift rod was to short so i had to by a longer rod. i changed all of my gauges to the Classic Instruments. I had them put the red needles in so they look almost factory. It is going to work out very nicely. i have about 200 miles on it. Next will be an Eaton Posi and 3:73 or 3:42 gears. i am leaning towards the 3:73.
Early Classic 4.5/6
Old 03-26-2018, 09:22 PM   #7
bluek5
bluek5's Avatar
Originally Posted by 2500HD View Post
I do not know how to rotate the pictures.
I just saved them to my phone and then edited them.
bluek5 is offline   Reply With Quote
Old 03-26-2018, 09:32 PM   #8
Fraud
Thanks for the info, looks awesome
Old 03-29-2018, 03:18 PM   #9
2500HD
2500HD's Avatar
Are you working on something like it? There are a lot of little things i may be able to help with. Like motor mounts, headers and such.
Early Classic 4.5/6
