Old 11-09-2003, 12:00 AM   #1
69ChevySB
dropped69
please help with motor and idle
ok i just put the new 350 block and turbo 400 in when i am cruising sometimes and i come to a stop, when i start to accelerate again my truck feels like it wants to die so i have to give it more gas than usual...also what is my truck supposed to idle at on my rpm gauge? someone said my truck is running to rich thats why it feels like it is gonna die when i start going and a couple times it did die. how do i know what to adjust the 2 screws in the front of my edelbrock carb to? help please i want to drive and break my motor in but i dont want it to die like it did earlier. thanks lots.
"And yet I find, yet I find...repeating in my head. If I can't be my own, I feel better dead." -Layne Staley (R.I.P)
69ChevySB is offline   Reply With Quote
Old 11-09-2003, 12:35 AM   #2
rickh
Best way to set the carb is using a vacuum gauge. You do this with the gauge hooked up and the truck running. You adjust the jets for the most vacuum. You should also have the timming set to 8-10 deg BTDC (or up to 12 if you can get good gas) and the idel set around 600-700 for auto (if I remember correctly).
The jets on the carb can be touchy. Does the truck idle good? How does the exhaust smell? Burn your eyes?
Other causes of stumble could be an air leak on the intake or the carb mount, these are easy to find, if it is idling rough, spray some WD40 around the base of the carb or along the intake gasket, if the idle speeds up, you found a leak.
Was the engine you put in a long block? Maybe the rockers are not adjusted correctly, if so, you will never be able to tune that out with out adjusting them.
Rick H...
Rick H....
69 C10-CST
Wood bed floor full power
70 SWB 425hp HOTROD!
Full power
71 C20 Camper Special
402 full power, factory dual tanks with gauge switch. FOR SALE!
rickh is offline   Reply With Quote
Old 11-09-2003, 12:39 AM   #3
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Check for a vacuum leak before you start twiddling with the carb and, like rickh said, make sure you didn't set the valves too tight. Oh, and be sure you're timing is reasonable (I generally start at 8-10 degrees and creep up until I ping or it gets hard to start when hot, but others prefer more scientific methods). In short, there's at least a dozen things to double-check before you start playing with the carb.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 11-09-2003, 12:42 AM   #4
shuttermutt
Geez, almost forgot. I generally like mine to idle at around 800 rpm (no choke and a known good vacuum advance). I like to set automatic tranny vehicles a tiny bit higher than manuals.
'Mutt
Old 11-09-2003, 02:55 AM   #5
bpmcgee
bpmcgee's Avatar
One thing to remember is that those needles only set IDLE mixture. Once you step on the gas, the accelerator pump kicks and you're off on the main circuit.
The main circuit mixture is controlled entirely by the main jets, that have to swapped out to play with the mixture.
Brian
bpmcgee is offline   Reply With Quote
