03-28-2018, 08:01 PM | #1 |
402 dipstick tube?
I took off the exhaust manifold on the passenger side to fix a broken flange stud and when I did, I just pulled and twisted the dipstick tube to get it out of the way. Now I can't get it to go back in, is there some trick to getting it back in? 72 C20 with a stock 402.
03-28-2018, 08:04 PM | #2 |
Re: 402 dipstick tube?
Gotta hit the hole !.....
Stan 67 swb BLU MULE posted via flip-fone |
03-28-2018, 09:12 PM | #3 |
It only goes in 1/4 inch or so and feels like it's hitting something hard. Is there and O-ring or something in there? I'll keep wiggling, it was tight coming out!
03-29-2018, 12:38 AM | #4 |
Find a flare nut wrench like for brake lines to go around the tube.Place it at the flare on the bottom of the tube and drive it in with a hammer.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
03-29-2018, 07:47 AM | #5 |
There is a O-ring in there,you have to pull that out,make sure it is not damaged,slide it back on the dipstick,add a dab of silicone,and wiggle and push it back down,should be just fine.
03-29-2018, 04:23 PM | #6 |
It was the o-ring. Took the manifold back off and crawled in there and could see the o-ring. Got it out in two pieces, it was real hard and 47 years old. Replaced it and it all went together. I'm glad I didn't just force the tube in and push the ring into the pan, it was surprisingly hard when I pushed on the tube and felt like a metal lip or something.
03-29-2018, 08:25 PM | #7 |
Glad I could help.
