'50 GMC build
First, thanks for all the help on last build, the '59 Apache rolled out a couple weeks ago, owner quite happy. That project was all paint & body work, new roof, floors, corners, door skins ect...this site was great help!
Rolled it out, rolled this in, 1950 GMC 1/2 ton. Truck is waaaaay better shape than the last, other than usual corners, floors, this truck is very solid, even has the running boards that like the rest of the truck, is very light surface rust. Already have a LS4L60e out of 2002 Tahoe, just scored a 10 bolt out of '79 TA, just needs gears, welded in Mustang II IFS X member. I think my next step is needing to get rear end& springs in finish putting front end together, then mock up LS/tranny. I am a paint & body guy, so I have jumped into a new world with the LS swap, tranny swap, ect. What I need now is info on what springs to use. I measured 52" for the original spring hangers. 1st question - can I use 52" (26/26) leafs with original hangers, , or do I need to go with the original springs (25 1/2-29"). Will the 26-26 change the center line for axles? Should I just remove original hangers and go with all new stuff, if so really look forward to any direction that way. Hope that made sense? I'd like to keep close to original stance. I scored some really nice Foose wheels/tires 17-7, 235/40 frt - 17-9, 275/40 rear. I think once I get the spring/rear end done, I can really start cruising along. Thanks, Kel |
Re: '50 GMC build
Welcome to the LS party! Looks like you're going a similar route as me. My project is slow (9 years and counting) but so far my 1950 Chevy has its Fatman Mustang II IFS installed and I went with a TCI rear leaf spring kit. I also have an 5.3L/4l60e combo between the frame rails. I am close to getting it to run.
Maybe we can exchange tips and ideas along the way. I won't fill your thread with pictures and stuff but you can check out my build thread in my signature if you like. |
#3 | |
Re: '50 GMC build
BTW, here is what I've done so far - https://photos.google.com/share/AF1Q...pzRG05T0NQWF9n |
Re: '50 GMC build
If anyone could post pics of their non stock leaf spring setup, and a little info on, would be much appreciated, Kel
Re: '50 GMC build
Sorry photobucket's crap rules won't let you see the pics in my thread. Here are just a few of what my truck looks like. The TCI rear leaf spring kit lowered the truck about 3 inches but didn't move the wheels forward or backward. The kit is made for a 3 inch axle tube so I had to modify for my 3.25 inch tube.
Re: '50 GMC build
Thanks Greg. I went ahead and ordered the stock springs. I had removed the originals front hangers, thinking I was going to go in different direction, so for now, I tacked the hangers back on. Hope to get chassis rolling by the weekend, Kel
Re: '50 GMC build
The TCI parabolic rear kit I got for my 50 lowered, and centered the rear end in the fender wells. Stock is a bit toward the front.
#8 | ||
Re: '50 GMC build
