Old 03-29-2018, 11:36 AM   #1
riz
lowered springs and tubular control arms ???
I'm struggling to get my 2" lowered McGaughys springs into the frame cup and my POL tubular control arms???
I swing the control arm down far and insert the spring into the frame cup but as I raise the lower control arm the spring slides out of the control arm pocket ???
Do I have to compress the lowered spring ???
I've seen plenty of videos where people just slide them in and raise up the control arms....
what am I doing wrong ???
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 03-29-2018, 08:03 PM   #2
Bloodhound
Re: lowered springs and tubular control arms ???
I am in the middle of this with POL arms and stock height springs. I have determined I definitely need a spring compressor.
Bloodhound is offline   Reply With Quote
Old 03-29-2018, 11:34 PM   #3
Gregski
Post Whore
Gregski's Avatar
man I bought two sets of McGauphys coil springs and returned them both, I really had a bad experience with their 2" drop I think it lowered my front end like 4" inches, here is a link to my write up on it, I hope you have better luck
http://67-72chevytrucks.com/vboard/s...ight=McGauphys
Gregski is offline   Reply With Quote
Old 03-30-2018, 07:21 AM   #4
zach_carver
zach_carver's Avatar
It really depends on how much lowering spring you have wether you have to compress them when installing or not. I have had to compress most lowering springs on camaros when installing, but they wasnt much drop either. Most drop springs on trucks I have done were either 3 or 4" drop springs so they fell right in. Them control arms may also be a tighter fir, Ive never used POL lowers.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 04-02-2018, 01:05 PM   #5
Bloodhound
Well I'm at a bit of a standstill. The only spring compressor I could find that I thought had a chance at working was still too small to compress the stock springs. I can't use a jack to compress the lower arm because of the lack of weight. Ideas?
