Old 03-30-2018, 09:51 AM   #1
MASONGMC
My 2005 GMC is loosing fuel pressure with no leaks anywhere
I need some help my 2005 GMC Sierra 1500hd 6.0 is loosing fuel pressure when it sit over nite .Have anybody have that problem?
MASONGMC is offline   Reply With Quote
Old 04-14-2018, 01:03 PM   #2
Bladeboy1998
Re: My 2005 GMC is loosing fuel pressure with no leaks anywhere
Could be leaking from the sending unit in the tank and back into the tank, or you could have an injector that is seeping slightly. Or even a bad fuel pressure regulator
Bladeboy1998 is offline   Reply With Quote
Old 04-16-2018, 03:58 PM   #3
gearheadperkins
gearheadperkins's Avatar
x2 on the Fuel pressure regulator..
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 04-21-2018, 07:41 AM   #4
homemade87
What are your symptoms . Why do you think this is a problem . If it drops in a minute or two , there may be something wrong . If you have a pressure gauge checking let it set for a 5 min and see what it does . Most systems will not hold 100% pressure over night . It will loose some and usually is not a problem . What is yours doing .
homemade87 is offline   Reply With Quote
