03-30-2018, 11:08 AM | #1 |
WTD u bolt saddles for a 1959
Hi, looking for u bolt saddles for a 55t 1959 rear end. I think the part # is 3711650. I would have posted in the parts section but the site didn't allow me too do so. This is a picture of the part type I would need but not the proper size. If someone has a set I could buy that would be great.
03-30-2018, 08:37 PM | #2 |
Re: WTD u bolt saddles for a 1959
ttt
03-30-2018, 10:47 PM | #3 |
The site doesn't allow you to post parts requests or items for sale in classifieds or on here (not at all here) if you are not a paid supporting member.
I know of no one who sells that item new.
03-31-2018, 07:03 AM | #4 |
I was hoping someone had a set used I can buy.I figure someone who took there rear out for an upgrade may have them.
03-31-2018, 09:19 AM | #5 |
Are you opposed to just using u-bolts and and a top plate? Or are you trying to be period correct?
03-31-2018, 10:49 AM | #6 |
I think by the other threads he has he is trying to take a truck that has been modified and had changes and change it back to show room stock.
03-31-2018, 05:38 PM | #7 |
I would like it period correct but I still need to get the shock brackets on as well.If I can't get the saddles I may have no choice. I still can't believe Iam having such a hard time finding these oem saddles as most people change there rears out. Iam willing to pay.
03-31-2018, 07:51 PM | #8 |
i have a set you can have
need to declutter my barn
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-31-2018, 09:14 PM | #9 |
Thank you so much.I sent you my cell...Anthony
04-01-2018, 03:58 PM | #10 |
didn't receive a cell or pm from you
here they are part ArmaSteel #3737372 sandblasted and painted with por15 back in 2003 plus 1 spring bracket, didn't see the other bracket
04-01-2018, 04:02 PM | #11 |
i have 2 original U-bolts and 4 new U-bolts in the bag
not sure i would use the original U-bolts when i have 4 new ones
04-01-2018, 04:05 PM | #12 |
these are stock from a 58 truck if you are changing to a bigger axle than stock they will fit
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 04-01-2018 at 04:10 PM. |
04-01-2018, 05:17 PM | #13 |
Hi, do you have the saddles for the 3" tube rear?
04-01-2018, 05:31 PM | #14 |
These are the saddle I have. They measure 2 3/4 across. I need 3" across
04-02-2018, 07:02 AM | #15 |
There were two different axles that year from what I understand. One was the dana 45 and the 55t. the dana 45 was 2 3/4 inch thick and the 55t rear was 3". I changed from the dana 45 to the 55t. this is why I need the other saddles to fit the 55t.
04-02-2018, 03:04 PM | #16 |
Still Loooking
04-03-2018, 07:09 PM | #17 |
Today I found out that the rebuilt rear that I'm looking to put in is an eaton ho33. if anyone has a set of plates that would be great. thanks
04-07-2018, 09:27 PM | #18 |
i got a chance to measure mine today... 3''
i believe the ones you have are the same size but your welcome to mine using a 3'' drum sander drum to test fit
04-08-2018, 01:48 PM | #19 |
all packed up like grandma's fine china
should go out in the morning
04-08-2018, 07:05 PM | #20 |
Aw thank you so much and thank you to Dave for the support.
04-09-2018, 12:15 PM | #21 |
dropped it this morning at the post office, start looking for it wednesday
04-09-2018, 05:15 PM | #22 |
One more thing, does anyone know the torque specs for the rear u bolts?
04-09-2018, 07:31 PM | #23 |
1/2-20 = 75 to 90 ft. lbs.
chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0471.htm 54, 55 2nd series and many others. |
04-09-2018, 08:02 PM | #24 |
thank you so much
04-10-2018, 12:28 PM | #25 |
f'ing tight
