03-30-2018, 05:48 PM | #1 |
No see em 20 gallon gas tank--started
I removed the rear most cross member and fabricated a new one out of an I-beam. Made a cardboard pattern, cut a slot for the bed cross member (will fab a new one to make room for the elevated tank) and mounted it in place. With the rear pan in place the tank wasn't visible when I was kneeling 25 feet back. So far I have the tank sides tacked, the top ready and two baffles made. I will add another baffle in the morning and weld in place. I have holes drilled in the top for the vend and the feed. I have to get a 2 5/8 holes saw for the sender flange. The tank is mounted 1 1/2" above the rails and is longer because I moved the rear cross member. I will be 20 gallons. Will post more photos as I progress.
03-30-2018, 09:21 PM | #2 |
Re: No see em 20 gallon gas tank--started
Nice job, go into production and you could sell them!
03-31-2018, 05:05 PM | #3 |
Finished the baffles. Drilled and tacked the vent, pickup and sender bungs. Will tack the baffles, mount brackets and lid in place soon.
04-01-2018, 11:09 AM | #4 |
Subscribed
04-08-2018, 04:33 PM | #5 |
All tacked together except the mount brackets. Trial mounted it to mark for the brackets. Standing behind it can't be seen.
