Old 03-30-2018, 08:05 PM   #1
bsask80
bsask80's Avatar
Location: Coderre, SK. Canada( really close to nowhere)
‘64 K20 factory tach
Have a ‘64 K20 with a factory tach. Don’t know what engine was original. Has a 454 with hei ignition now. Tach needle moves but only goes from 0 to about 1500 rpm. What should I be checking ?
bsask80 is offline   Reply With Quote
Old 03-30-2018, 10:19 PM   #2
Nanook
Nanook's Avatar
Re: ‘64 K20 factory tach
You need to pull the gauge cluster and remove the tach to see if it is for a 6 cylinder or an eight. They are different tachs and cannot be interchanged.
There should be a sticker on the back that will tell you.
Pictures would help...
Nanook is offline   Reply With Quote
Old 03-30-2018, 11:57 PM   #3
bsask80
bsask80's Avatar
I will have to take some pics. And sounds like pull the cluster. Could maybe do some research on my vin and see what engine it came with also I guess
Old 03-31-2018, 01:20 AM   #4
Captainfab
60-66 Nut
The VIN will not tell you what engine the truck came with from the factory. Also, most gauge clusters with factory tachs came in the medium duty trucks. So your gauge cluster may not be original to your truck. And an original tach will not work with a HEI.
Old 03-31-2018, 11:05 AM   #5
bsask80
bsask80's Avatar
So it really doesn’t matter what tach I have then if an original won’t work with hei
Old 04-01-2018, 09:28 AM   #6
VictoriaHardware
VictoriaHardware's Avatar
I have a '65 V8 tach that does the same thing. It's very stable, smooth, and accurate- I checked it against a Sun tach/dwell meter. Only problem is it won't go higher than 1500 rpm. Not sure if someone repairs these or they are just not worth the cost/effort. Should I just buy a new repro?
VictoriaHardware is offline   Reply With Quote
Old 04-02-2018, 09:32 AM   #7
Ken Cook
Ken Cook's Avatar
Call RedlineG.com
He should be able to help.
Ken Cook is offline   Reply With Quote
Old 04-08-2018, 08:58 AM   #8
rideblue00
rideblue00's Avatar
if you decide to change up to a new one, check out my tach install thread
http://67-72chevytrucks.com/vboard/s...d.php?t=499570
rideblue00 is offline   Reply With Quote
