Old 03-31-2018, 01:20 AM   #1
Cooper197
Cooper197's Avatar
Turn Signal Issue
I just finished up re-wiring my '66, so I'm assuming the issue is that I have something backwards.
When I use the turn signals, the front light up and the dash indicator turns on but stay constant, neither blink. The rear lights do not come on at all, however the brake lights do work along with all park lights.
I have all LED lights and used an LED flasher before I did the rewire. I popped that in just to see if it made a difference and with that absolutely nothing happens when you hit the turn signal.
I've double checked the wiring, but it all seems to look correct. Anybody have an idea on what could cause such an issue?
*Problem solved. LED flasher ended up being bad. All works great with a new one*
Cooper197 is offline   Reply With Quote
