Old 03-31-2018, 08:05 PM   #1
WastedTime
Bagging rear - 1970 c10 with trailing arms (lowering block question)
Quick question for those who've bagged the rear of a 70 c10 with trailing arms. I have airlift dominator 2600 lb bags which don't exactly bolt into the stock spring location so I've built a set of 2" cups to accommodate the fittings in the bag. The problem is I am going to need lowering blocks... right now I am not notching the truck but will eventually step notch it. With the step notch, I feel like I'm going to need huge drop blocks to allow the truck to come close to laying. Is anyone else runninginto this? I'm thinking of moving the bags forward on the arms and using s new upper mounting bracket. Thoughts? Thanks guys!!
WastedTime is offline   Reply With Quote
Old 04-04-2018, 02:44 PM   #2
68is4me
68is4me's Avatar
Re: Bagging rear - 1970 c10 with trailing arms (lowering block question)
Yes, running blocks is common to get the rear ride height were you want it. I am using either 1.5 or 2 inch lowering blocks don't remember which ones. But I am also notched.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
