Old 11-09-2003, 09:31 AM   #1
c10rookie
c10rookie's Avatar
brake problem
Hi guys, can anyone advise on the following ? We recently have the brake light showing on the dash, is this only a footbrake warning light or does it warn of other things ? The brakes seem OK and fluid is full, but some times when the light comes on and we stop in traffic and push pedal down real hard we get a bang from the rear ? but only sometimes. pads and shoes seem good.
if it aint broke , fix it till it is
355- flat tops - 70cc RPM heads 9.5:1
RPM inlet MSD6 & HEI
headmans & glasspacks
Crane .467/.494 278/290 222/234 114
1.6 roller's 2400 tci 650 Holley
cold air induction electric w/pump,fans,f/pump
c10rookie is offline   Reply With Quote
Old 11-12-2003, 06:00 PM   #2
Insanemadhatter
Take a look at your emergency brake and see if it retracts when you let it out.
Scott
Daily Driver
Was giving to me by old roomate
on 10-10-03 Thanks Dan
1987 K5
Small Block 400
holley 690 TB
4" Lift 33's and
MSD ingintion soon to come.
Wheeler
1988 Toyota Pickup
Ivan stewart Fiberglass Fender
3" suspension Lift
33" BF MT's
Lincoln Locked oh-yeah
V6
External roll cage and 350 soon to come
Insanemadhatter is offline   Reply With Quote
Old 11-12-2003, 06:48 PM   #3
c10rookie
c10rookie's Avatar
We have started to loose pressure on pedal know as well, this looks like it may be servo or master cylinder ???
