Old 04-01-2018, 01:57 PM   #1
mosel70
Polyester Hi-fill Primer Question
Giving my '70 Chevy C10 a full repaint, int and ext.
I'm using Eastwood's Contour Polyester Primer-Surfacer. Mostly over sanded OEM paint, but a few small spots of bondo and bare metal and a few new parts (hood, front fenders, tail gate) .
https://www.eastwood.com/eastwood-co...-surfacer.html
I used 2 gallons of primer, 2.5 tip, 20oz primer, 1oz hardener, 3 oz acetone, 80 degrees, 15% humidity. Sprayed on nice. But, I ran out of primer before giving everything its first coat.
2 questions
a. will it hurt to give panels their second coat a week after the first coat dried?
b. should I sand the first coat before applying the second coat of primer?
mosel70 is offline   Reply With Quote
Old 04-01-2018, 02:18 PM   #2
harpo231
harpo231's Avatar
Re: Polyester Hi-fill Primer Question
I wouln't sand till covered....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 04-01-2018, 02:29 PM   #3
projectking
projectking's Avatar
Follow the data page, if maximum recoat time is exceeded then you at least need to sand the overlap to finish the first coat.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-02-2018, 09:45 AM   #4
StingRay
StingRay's Avatar
A week will be outside the re-coat window. I'd be sanding it wherever new material will cover the first application.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
