Old 04-01-2018, 05:48 PM   #1
Dodge68charger
Installing Pitman Arm And Center Link
How Do I Go About Istalling The Pitmam arm So It Is Centered. I counted The Turns and Put in On Facing Straight Back But When I Went To Install The Center Link Iot Made It Face The Passenger Side.
How Do I Get Everything Straight? Thank You
Dodge68charger is offline   Reply With Quote
Old 04-02-2018, 01:25 AM   #2
Toms67
Toms67's Avatar
Re: Installing Pitman Arm And Center Link
I think if you check your Idler arm. It can go on two different ways. I think I had that same problem when I put mine back in. If you had your idler arm off?
Toms67 is offline   Reply With Quote
Old 04-02-2018, 01:46 AM   #3
Dodge68charger
Idler Arm Was Off.. I ll Get an FsmTmrw
Old 04-02-2018, 01:55 AM   #4
Dodge68charger
Just Seems The Center Link Needs To Be longer
Old 04-02-2018, 06:06 AM   #5
Toms67
Toms67's Avatar
Did this center Link come off this vehicle? If so. Could that be backwards also? And there is a tapered side. If you do a search on The form on center link you should come up with some pictures. Also if you could take some pictures and post them. That will help also. There are a lot of people on here they’ve been through the same thing. I’m sure someone can figure it out.
Old 04-02-2018, 03:57 PM   #6
Dodge68charger
Old 04-02-2018, 03:59 PM   #7
Dodge68charger
With The Idler Arm maxed To Towards The Steering Box and The Pitman arm Pointed Straight Back Its Not close To lining up
Old 04-02-2018, 04:02 PM   #8
Dodge68charger
Not Sure If This Is The Right center link. Its a70 c10 with a crossmember off an 1987 2wd suburban
Old 04-02-2018, 04:41 PM   #9
demian5
demian5's Avatar
And the truth comes out. But since the box and idler are bolted to the frame, the center link should be the same as the frame model and year.
Make sure center link mounts so nuts face forward on tie rod ends (center link center closest to cross member). However I do not know that if you use the 73 and later cross member, will the center link hit the frame when installed properly...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-03-2018, 01:41 AM   #10
Dodge68charger
The Measurement center To Center of Both pitman arm and Idler arm when Pointing straight Back Towards The Rear Of The Truck Is 31 inches.
Old 04-03-2018, 02:09 AM   #11
un4gvn!
un4gvn!'s Avatar
You have the idler arm in the wrong hole. The idler arm and pitman arm bolt to the outer holes. The tie rods bolt to the inner holes.
un4gvn! is offline   Reply With Quote
Old 04-03-2018, 11:37 PM   #12
Dodge68charger
Problem Solved. Thank You
