Help with Carrier Bearing Angles
So, where to begin. I've had this truck for several years now and the truck has always had an issue with wheel hop. Just recently took it to a shop and they said that when the truck was built they did not set the drivetrain at the correct angles. The mechanic says that the truck drivetrain needs lowered at least 8". Can anyone help me determine if this is accurate or not? The truck is a 51 GMC body and sits on a 74 k5 frame.
Thanks, Wayne |
Re: Help with Carrier Bearing Angles
see if any of this info helps.
http://spicerparts.com/anglemaster/measuring-angles http://www.4xshaft.com/driveline101.asp https://www.drivelinesnw.com/part-tr...ngle-problems/
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60. 1972 CST K5 350/th350/12blt,eaton posi/D44 1970 K10 SWB 1970 K20 350/th350 |
Thanks for your help. I'll try this and see what I can come up with.
Post Whore
![]() ![]() Join Date: May 2015
drivetrain lowered 8"????.....how much angle is on your driveshaft?...drivetrain angle is different than just lowering a drivetrain...and carrier bearing is another...but all related
the 51 body sitting on the k5 frame [in itself] wouldn't cause driveline angle issues if engine, transmission, transfer case are still mounted to the k5 frame the angles shouldn't have changed that much [not 8"] unless theres a huge lift kit involved.... and I wouldn't have thought a k5 had a hanger bearing
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-14-2018 at 07:44 PM. |
