Old 04-02-2018, 08:04 AM   #1
trukman1
1988 K5 Dual Exhaust Kits
Does anyone have a suggestion for a dual exhaust kit (with long tube headers) that actually fits right? I went on Summits website and they list Dynamax and Hooker but the kits look the same and reviews all said the passenger side tailpipes fit but not the drivers side. The pictures show the pipes being different.
Can anybody recommend a kit that fits right?
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 04-02-2018, 08:16 AM   #2
sweetk30
sweetk30's Avatar
Re: 1988 K5 Dual Exhaust Kits
make sure you do 90* or 45* out the sides . if you do out the back end on blazers or suburbans with tailgate window down guys say the exhaust fumes are nasty in the cab .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-04-2018, 08:45 AM   #3
trukman1
Thanks but the kits I mentioned are both side exit kits. I planned to have the pipes exit behind the rear tires but all the kits I see listed show the left tailpipe bent differently from the right (not mirrored bends.) Reviews say the right side works correctly but the left side does not and needs to be bent like the right side only "mirrored" of course. I am trying to see if anyone makes a kit with the correct bends for both sides.
Anybody have any other brands I might check out?
Old 04-04-2018, 06:54 PM   #4
BHTH
I have my heart set on duals straight out the back I wonder if you have the wing windows open would it fight exhaust coming in the rear window?
BHTH is offline   Reply With Quote
Old 04-04-2018, 07:09 PM   #5
sweetk30
sweetk30's Avatar
lots of guys over on ck5 for years have said its nasty in the blazer / suburbans if stright out the back . i am a truck guy so i have no first nose experience .
Old 04-04-2018, 08:32 PM   #6
trukman1
All the kits I've seen are exiting behind the rear wheels.
Again, anybody know of any "kits" that fit properly?
Not trying to be rude I appreciate the input but I'd like to get this post back on track.
Thanks.
Old 04-04-2018, 08:37 PM   #7
sweetk30
sweetk30's Avatar
might be faster and better to just hit up your local exhaust shop and have a system custom bent just the way you want it .
Old 04-04-2018, 11:16 PM   #8
Jaysonb
Jaysonb's Avatar
I have used the hooker kit on my k10, and the dynmax kit on 3 c10s, it's just pipe, if you can't tweak it a little here and there to make it fit to your liking, then it would be best to go to a shop and have some exhaust bent up for you. I think the kits are a great value for guys with a little mechanical common sense.
Jaysonb is offline   Reply With Quote
Old 04-04-2018, 11:24 PM   #9
BHTH
Thanks I'll have to go check that out. Truckman you might have better luck if you post in the blazer section...or go to a shop.
Old 04-05-2018, 08:18 AM   #10
trukman1
Jasonb, I've been wrenching and restoring for over fifty years but after getting paralyzed twenty one years ago I'm not thrilled by tweaking so much anymore. I figure there must be a kit out there that is a bolt in without having to "tweak" especially if it means having to re-bend pipes that should fit.
Just looking for a kit that's made right from the start. At my age I just want to get something I can put on that works out of the box.
Thanks.
Old 04-05-2018, 08:21 AM   #11
trukman1
BHTH, I don't know why but I didn't even realize there is a blazer section. It sucks getting old! (Guess it beats the alternative!) LOL!
Thanks!
