Old 11-09-2003, 01:54 PM   #1
wxman1
Flow(Masters?)
Well I wanted to replace the cheapass
parts store mufflers currently on my
69 C10 P/U with 350/th350. They are light
guage metal and sound like it. So I bought
a set of 50 series Flowmasters. There seem
to be rather strong opinions on these mufflers
but compared to the crapola that I have on
now, they're an improvement. (They were
on sale to boot)
My question is...do I have to put a continous
bead around each joint or can I tack weld
each joint instead?
Also...do they tend to run higher temperatures
than other mufflers? Will I have to use heat shields?
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 11-09-2003, 02:48 PM   #2
miket
miket's Avatar
WXMAN1:
Not sure about the wld question....but I have 40's on mine that are mounted pretty darn close to the bottom of the bed....they get very hot...in fact if my bed was wood...I would either have them moved or have heat shields installed. I think it will depend on where you install them.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 11-09-2003, 02:54 PM   #3
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
I have them on my 74 with approximately 4 inch clearance from the wood bed. No probs. I also was concerned at first. I don't know how much clearance you will have though.
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 11-09-2003, 03:02 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
put a weld all the way around, or it will leak on you. As for spacing, a few inches should be fine. Mine is ~5" from my bed (not wood). I can feel the bed get warm when driving around, but not hot... But it does melt all of the snow out of my bed in the front half of my bed
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-09-2003, 04:47 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
My 40's are about 4-5" under my metal bed....no heat problems. No tailpipes either, the mufflers just end there.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-09-2003, 05:00 PM   #6
junkyardjohn
junkyardjohn's Avatar
I JUST BOUGHT SOME 40 SERIES FLOWMASTERS ON EBAY FOR $37 EACH. I'VE PREVEIOSLY (SP) BOUGHT THEM THRU SUMMIT FOR ABOUT $65 SO THIS SEEMED LIKE A GOOD PRICE. THIS GUY HAS A DUTCH AUCTION GOING ALL THE TIME, SO JUST DO A SEARCH FOR FLOWMASTER ON EBAY. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
