Hello experts in the community, recently I have been experiencing issues with my SBC (GM crate 350 4-bolt w/10,000 miles). I have erratic timing at idle, lower than normal vacuum (18") and low cylinder compression (110psi) evenly on all cylinders. I did a performed a chain stretch test and saw 12 degrees of slack, way too much! I have babied this motor since I bought it new, heck it has never seen temps over 180 Deg. and has had meticulous oil changes. It looks like I'm in the market for a new timing chain...
So the question arises, what is a good quality, long lasting timing chain. I do not want to take the chance of one breaking or having it stretch so early on into its life ever again. I have the CompCams 3 piece timing cover (PN 310), so space will not be an issue; also my budget for the chain is 200.00. I'm just looking for a quality piece that will last me as long as possible. Part numbers are welcomed, thank you in advance for your expert input. Bryan B. Last edited by beanious; 04-02-2018 at 07:10 PM. |
Re: Best Timing Chain SBC 350
I’d recommend a double roller. I have a Rollmaster billet double roller in my 331 sbc Nova gasser. After about 60 1/4 mile passes, no issues at all. I’m sure Summit or Jegs has decent Cloyes, Edelbrock, or even some house brands. They all hold up well.
Customization is what you want it to look like -- not what other people think it should look like |
Sounds like some good recommendations, double roller, billet. Hopefully I can get some 100,000 mi. recommendations from some members out there...
![]() I figure it's a good topic to throw out during the Easters break... |
![]() Join Date: Oct 2009
Cloyes is one of the best, but from the link here, you can see all major cam manufacturers offer them also - all the way down to $29.99. I don't think billet gears are necessary for a street driven, stock truck - the main reason to get away from a "stock" chain is the neoprene teeth. So, really, any metal chain with steel/iron sprockets is an upgrade, and one that will last. Having said that, there IS a slight pecking order inside the double roller world also. Some double rollers are just basic double rollers (i.e. two rows) and then there are "true" rollers - they have links that are more like a bicycle chain that rotate also. I'd opt for a true roller personally, but, again - ANY all metal setup is an improvement over stock. It's also nice if the Torrington bearing is included (I think that's what it's called..) Personally, I think the extra slots for adv/ret are over-rated. If you're running a stock setup, that additional cost isn't really necessary - but many many of the chains out there have the three keyways. Doesn't hurt anything to have it, but not necessarily worth paying extra for if you're pretty stock. If you plan to degree the cam, it's a handy option depending on what you discover when doing so.
Which GM crate did you start with? I'd be surprised if it came with a neoprene chain unless is was the 190/260/290 Gen I version they sell. Those may have neoprene, not sure. How many miles have you put on this chain? 12 deg is huge... Summit Selection: https://www.summitracing.com/search/...ll-block-gen-I I like this basic double roller True roller https://www.summitracing.com/parts/c...make/chevrolet Here's a fancy one if money is burning a hole in your pocket - includes hex-adjust and billet sprockets and torrington bearing. (Hex adjust is a small insert on the dowel pin (or something like that) that allows fine tuning of the cam. Not really necessary, but handy depending on your tuning comfort level. https://www.summitracing.com/parts/c...make/chevrolet As you can see, prices vary widely depending on cool factor and neat little gee whiz things. Basic works just fine. The base for me is the 2nd link above. But I sure like the last one too... ![]() Last edited by jocko; 04-02-2018 at 07:40 PM. |
#5 | |
![]() Join Date: Jan 2001
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Gear drive? Longevity and the sound...
Jocko, thanks for the advice. I appreciate the information on true double roller vs standard double roller, I will be sure to to get the true!
I had at one time considered a gear drive setup. However it seems like either they last forever or grenade your engine, that plus the constant noise of even the quiet drives pushed me away from them. I am always listening for vibrations, noises and problems and the whine would probably grate get on my nerves. That being said, when set-up properly 100K is no problem.
#9 | |
The next leap in tech was the Jesel belt drive and they are fantastic. Honestly, a decent double roller is best for street car based on reliability and streetability. Hex adjust is great for a guy that races and spends alot of time tuning for different conditions. For a DD, double roller is more than adequate. Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess ![]() 06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it. 67 El Camino Custom 300 Deluxe. In progress. 55 GMC 371 2 1/2 ton. Upcoming project. |
So, I think I may have settled on the timing chain...
CompCams CCA-7100 Billet hardened upper sprocket Billet hardened lower sprocket Pre-stretched heat treated double roller timing chain /w large pins Torrington roller thrust bearing included Adjustable in 2 Deg. incr. max 8 Deg. No issues with fitment with stock cover 5 Stars on Summitracing site $94.99 I've always had good luck with CompCams what do you guys think? ? ? ? |
I've had one, I was 17 and wanted it to sound like I'd somehow stuffed a blower under the hood of a 57 bel air, because, well, I couldn't afford a blower
![]() Yes, zero stretch, but not really necessary. |
Solid component. I think it will be great. Now the question is if you will take advantage of it and go through the process of degreeing the cam?
Dan
#13 |
![]() Join Date: Dec 2009
For a SBC a double roller or gear drive is a good choice.
I have run both . Gear drive is my choice. As long as there is no nylon or single chain your OK |
#14 | ||
"I ain't nobody, dork."
Unless it's a drag truck... a full on billet timing set is a waste of money.
A plain' ol' Cloyes double roller at $30 bucks will be just fine. It'll last well over 100,000 miles. I have never babied an engine in any rig. From break-in to rebuild and all time in between... run the snot out of them. SBC's are made to take a beating from the factory. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
