Old 04-02-2018, 03:03 PM   #1
Stephen717
Stephen717's Avatar
Fuel line fitment issues
So I'm having a bit of trouble with my new fuel tank. Got it bolted in, new sending unit installed, and lock ring around the sending unit. Problem is I have the original fuel line in the truck and the new sending unit has a bigger fitting than the fuel line (which I'm pretty sure is 3/8" od). So my question is has anyone else had this problem and what did you do to solve it. Fuel tank and sending unit both came from LMC. Thanks
Stephen717 is offline   Reply With Quote
Old 04-02-2018, 04:44 PM   #2
B. W.
B. W.'s Avatar
Re: Fuel line fitment issues
These trucks came with 5/16" & 3/8" fuel lines out of the tank, my guess: you have 5/16 line and a 3/8" sender?
B. W. is offline   Reply With Quote
Old 04-02-2018, 05:46 PM   #3
FirstOwner69
FirstOwner69's Avatar
What B. W. said.
If I recall correctly, the 5/16" was used for 6 cylinder trucks and 3/8" was for V-8s.
FirstOwner69 is offline   Reply With Quote
