circuit board issues?
Pulled cluster today to touch up needles, replace oil pressure guage etc. WHile pulling the circuit board a couple of the nuts were sticking and it delaminated in these spots, also, the main plug has 3-4 copper connections that have come loose. I am cleaning with contact cleaner and checking continuity. Any other suggestions to ensure the board is ok? I am going back with LEDs too.
Re: circuit board issues?
I super glued the tabs back together and down
New board is pretty reasonable for as much work as it takes to get it out. Fix it once, fix it right.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Scrapper 1
that after market one are not as good as the factory one if you can find a used one i go that rout
